vsjay3
Thank you for your clear answer.nJust to confirm:nFor the liquids I use in my simulation model, only the density, specific heat capacity, thermal conductivity and viscosity properties are shown in the material properties dialogue box. So from your answer I take that density, specific heat capacity, thermal conductivity and viscosity are the only properties required for my simulation model.nThe reason I asked this is, I am currently creating a new fluid material in a User defined database for the same simulation model I'm running. So when creating a new fluid material, it will be correct if I only choose the density, specific heat capacity, thermal conductivity and viscosity properties from the available property list, correct ? (since they are the only properties shown in the material property dialogue box for my simulation model)nThank you very much!nn
