move to new topic to make it easier to find. nIf you look on here there are many threads on the same issue. Generally you're moving the mesh too quickly so reduce the time step. In your case you also need to check you aren't nipping out features, ie as you move the ground level are dips/hills with steep sides causing issues?n
