1shan
,nWhen you set the deformation behavior as rigid, all the surfaces that are scoped to the point mass become rigid in a sense. So if you have any boundary conditions/loads that are scoped to these surfaces (to which point mass is attached) it might create problems. Could ensure that this doesn't happen in your case. Also, provide an image of your boundary conditions, loads and surfaces to which remote point is scoped.nRegards,nIshan.n
