Navya C
Hi @ymore,nYou can look at these well-explained tutorials from the below link for maxwell fluent coupling.nArrayIf you are using a student version of the software you can follow the below forum discussion to understand how to get to this link.nIf you are using a student version of the software you can follow the below forum discussion to understand how to get to this link.nnFor the cooling channel, if the housing available from UDPs in Maxwell works for you you can use that or you can import a cooling system housing if you have it as a CAD model.nYou can set the housing as a nonmodel in maxwell and run the simulation.nIt advised having your cooling channel in maxwell though it is not participating in the electromagnetic simulation.nnRegards,nNavya
