March 25, 2021 at 3:14 pm
Is Compute Canada a LINUX/UNIX system?https://forum.ansys.com/discussion/comment/112551#Comment_112551
Hi Rob,nYes, it uses Linux/Unix system.nI also noticed that each time I execute 'write-case-data' command I get the above-mentioned error. However, when I export text-based results, let's say temperature data to a text file it works without any issue.nFirst I thought the problem may be due to not having to write access, but it seems it is not the case.
