March 25, 2021 at 3:57 pm
nThank you for your reply.nAt the moment, I will explore your suggestion for option A, as I have previous experience working with python scripts.nRegarding option B, I am interested on using Workbench because I need to run a parametric analysis that first solve the problem in Mechanical and then, it uses the result as an input for Fluent. I solved already the problem manually, so now I am trying to write a script to automatize the process.nRegards,nRamiron
