ndvp
Hi Ishan, thank you for the reply. I am able to select the surface at wall 2 and assign a temperature and keep wall 1 and 3 adiabatic but I'm not sure how to rotate all three walls at the same time. Also may I know if I rotate only wall 2 if this would be an issue? I'm currently trying to rotate all three walls together.nRegards,nndvpn
