March 25, 2021 at 5:16 pm
Hi Yogesh,nI recommend going through the Fluent Getting Started and Fluent Heat Transfer training courses on the Ansys Learning Hub to better understand how to set up a Fluent case. Then try setting up a Fluent only version of your case where you estimate the thermal heat generation. Then once this is running, you can run a coupled simulation with Fluent and Maxwell. The following tutorial that Navya suggested will show you how to use System Coupling to set up this coupled simulation. The main idea here is to start with a basic simulation and add complexity.nSteven
