Kyle
nTo use this signal you will have to somehow change lines 17 and 18 to create a vector that corresponds to your time signal. I don't think there are any built-in functions to create the type of signal you're interested in, unless you can use mathematical functions like the double Gaussian pulse example. Alternatively, if you have the data for the signal in a text file you could import the data with the readdata command:nn
