1shan
,nBearing connection allows for a non-linear coupling between the stiffness's in X and Y directions, mainly used for rotor-dynamics simulations. Given that, if you are not interested in rotor-dynamics, you should use the Revolute joint. Choose a body to body revolute joint and scope the respective surfaces under reference and mobile bodynRegards,nIshan. n
