Keyur Kanade
It must be stair stepping. Please check the geometry near the edges on which inflation is defined. Also please check if all required edges are defined under inflation. If some are misssing, then also it will create stairstepping. nPlease search stairstepping and you will get many discussions on this forum. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
