March 26, 2021 at 12:07 pm
Are the 2 machines able to communicate with each other? Can one ping the other? Are you able to telnet to all 3 licensing ports from tfl-02 to tfl-01? The necessary ports are 1055, 2325 and whichever port ansyslmd is currently running on. Starting with version 2021R1 you need to open the ansyslmd port, which you may need to set to a static port for firewall purposes. To do this, add PORT=XXXXX on the VENDOR line of the license file and restart the license manager, then open the firewall for that port.nExample:nVENDOR ansyslmd PORT=1056nnWhat are the errors seen on tfl-02?.ThanksnMattn
