DrAmine
Array that is wrong: he wants to use DPM Model.nArray: DPM is relying on Lagrangian Framework. You can add whatever you want as droplet as Injection. In the Injection you prescribe from where the particles should be injected, the flow rate, their initial velocity, diameter, etc...nnKeep default DPM Boundary at Inlet and Outlets.nAt the wall please change the DPM Boundary to Trap and enable EWF on that particular wall. For EWF Model activate DPM Coupling.
