The injections will flow as per the vector you initially set. Any slight distortion in the flow or mesh will tend to trigger a very slight eccentricity, this then cascades to generate small amounts of swirl. Have a look at the pitchfork bifurcation phenomena. In your case the inlet being off axis may be be enough to trigger the effect. n
