March 26, 2021 at 7:04 pm
Horizontal Slice through the Duct Treen
nVertical Slices through each duct, diffusers are pointing up.n
In Meshing, I named each diffuser outlet individually. Here is the Surface Integral Report on Mass Flow Rate: nFlow RatenVelocity Magnitude (m/s)(kg/s)n-------------------------------- --------------------ninlet 0.55125noutlet-a1 -0.033792286noutlet-a2 -0.049290673noutlet-a3 -0.064988827noutlet-a4 -0.075592129noutlet-b1 -0.023795012noutlet-b2 -0.039852063noutlet-b3 -0.065017148noutlet-b4 -0.084580287noutlet-c1 -0.060169858noutlet-c2 -0.080808306noutlet-d -0.039081787nwall-oneduct-px_duct-px 0n---------------- --------------------nNet -0.065718376nnNotice that there is a 12% mass flow rate imbalance since the Net value should be zero.nThis is because the Continuity Residual has not gone down sufficiently.n
I ran this for 1000 iterations and it didn't go down much further.nCFD experts, what is needed to get the Net Mass Flow smaller?n
