Naiara ArraynSlice on planes represented by the red lines. That way, the middle section is what ANSYS calls sweepable bodies. That allows you to have fewer nodes and elements in that middle section that it would if you did not do the slicing. Yes, it makes three times more bodies than you had, and Share Topology will allow the mesh to be congruent across these new faces as well as all the existing faces.n
