March 26, 2021 at 8:46 pm
nWhen you make a unit of a 3D truss and are going to stack 4 copies of it along the X-axis, then you need to leave out the bars on the +X side of the unit cube because the missing bars are going to be filled by the next cube that is copied in. When the last cube in the row is copied into the 4th position in the stack and that is the last cube, you have to fill in the missing bars on the +X side of that cube.nIf you are making a 2D pattern and copying the cube in the X and Y directions then you need to leave the bars on the +Y face out on the unit cube.nIf you are making a 3D pattern, then you need to leave the bars on the +Z face of the unit cube.n
