March 27, 2021 at 9:01 am
HinnNow you have duplicate bodies/materials and thus FE meshes inside each other which is not correct.nnIn order not to have to meshes inside each other which is wrong, we would need to do a Boolean operation between the bodies.nSee how that is done, that is subtracting the bodies (use the combine tool in SC):nnSo we get this :n
nSo we get two different meshes and that are not overlaid/overlapping like before - finally by sharing topology (see video for this:
" target="blank">), we get a full connected mesh at the interface/boundary between cube and sphere (see below - yellow marking showing the mesh compatibility at the boundary between cube and sphere):nn
