March 27, 2021 at 7:53 pm
nIn SpaceClaim, use Split Body to split the Header and Footer rails at each stud. Go from thisn
to thisn
Open the Header/Footer component, go to the Workbench tab and click the Share button to make sure the mesh connects across these new faces. Use those faces on the Revolute Joint. Note that on the header, I split it on the left side if the stud, while on the footer, I will split it on the right side of the stud.nChange all the hemp panels from Frictionless to Frictional with a 0.2 COF.tnIt will be better to make this a 2-step analysis. In step 1, apply the 5000 N to the top of the frame and keep that on during step 2. Make the shear force 0 in step 1 and apply that in step 2.n
