YasserSelima
Is it possible to write a single UDF incorporating both the mass source term as well as the wall heat fluxes?nYes .. you can write a UDF that has many macros, not just two.nOr a way to write time-dependent expressions of heat flux for selected walls in fluent setup?nYes, it is possible .. n
