OK, easier approach is to extrude the inlet section for 10-15 diameters and model just that part in a separate model. Use a uniform velocity inlet and write out a profile. Make sure the outlet of that model is in the same plane and orientation as the inlet to the main model and all good. Otherwise you need to re-orient the profile and that might be complicated given the shape. n
