March 29, 2021 at 11:53 am
Array The messages have nothing to do with licensing.nIf you are submitting the job interactively from the local AEDT, with the project open and specifying the hosts under HPC and Analysis Options -> Configurations, you only need to set it on the machine submitting the job. If you are using the Submit Job UI you would want to set it in the Batch Options.nBased on your previous post have you tried disabling the firewall to see if that will allow the job to run? If that works, you will need to open the firewall further as per the previous post. Typically the errors you are seeing are related to the MPI processes failing to communicate due to a firewall.nThe reason the job previously ran is because the Parametric Analysis isn't running with MPI though it does distribute.nn
