Karthik R
Administrator
Hello,nYou could potentially use bodies of influences for local mesh refinement. nRegarding your high aspect ratio: this might be a good thing if you want to limit the overall count. One of the advantages of hex meshing is that we can create stretched meshes in one direction. Again, you might want to inspect whether or not these high AR elements are in your regions of interest. If they are not, I wouldn't worry too much about them. Also, these are pretty common in inflation layers.nKarthikn
