erwin
If I understand correctly, this means that whatever material my turbine blade is, it won't affect the solution I get in Fluent? Therefore I have to use Mechanical and perform say, a static-structural analysis to determine the effect of blade material?nI also have a follow-up question. Say I perform simulation in Fluent to get the pressure loading on my wind turbine blade, is it possible to import the pressure values into Mechanical to perform FSI?n
