Sean Harvey
,If you select Solution, you will see cyclic solution display and under that the number of sectors. Can you try and setting to the number of desired sectors, then evaluate all results to check if you see more sectors? If you specify zero it will go back to program controlled and should display the full 360. Let us know if this helps. Thank you! Sean
