rfblumen
Hi Yangyee,nIt's really important to look at the flow solution before the solver diverges in order to better understand why the solver is diverging. When the solver fails, typically there isn't much in the output file to identify the issue. I would create a backup or stop the solver an iteration or two before the solver diverges and look at the results in CFD-Post. I would also suggest to run smaller positive incidence values to see what the behavior is.n
