March 30, 2021 at 12:07 am
So I can't go through the FMU route due to some restrictions by the company that made the battery model, but I have a problem regarding the Matlab-AAS, is there a guide for all the syntax to control fluent? For example, I need to get a value from an output parameter and transfer that value to a simulink model and the simulink model returns an input value for fluent. However if I use iFluentTuiInterpreter.doMenuCommandToString('report surface-integrals facet-avg ,5, temperature no'), it returns a string instead of a value that I can use for the battery model. How can I call that output as an actual number?n
