harshabharadwaj1
nAttached image is what I have when I compute the mass flow rate at the inlet and outlet.nYes, this is modeled as a two-phase flow with air and plastic. I had an issue with plastic appearing at the different parts of the outlet since the dimensions of my model is small (the cuboid section is 14mm). Hence, at the outlet I made the backflow of air as 1. nnThanks for the help.n
