harshabharadwaj1
,nThanks for the suggestion. But, when I extract the co-ordinates of an iso-surface, it is in CSV format and is in the from of a set of points. Do I have to manually make a curve around these points to create a surface and then import it to Spaceclaim?nIt would be great if you could elaborate a bit. Thanks a lot again.n
