icellb1
Hi,nI assume you opened a new design in 2020R1 and input your loss data again in the new design? If that's the case, could you test running your old 19.0 design in 2020R1: run your 19.0 maxwell design in 2020R1 without changing anything, to see if it gives different core loss. nAnother thing is in early versions if you set Kdc=0 the solver will automatically set it to 0.65, starting from 2019R2 Kdc=0 means 0 not 0.65 anymore. This may cause some difference. n
