1shan
,nAdaptive sizing refines edges based on curvature and proximity but does not carry this refinement along the face to which the edge is attached. So you might have a mesh which captures the edge geometry accurately but with a poor face mesh. In such cases you could use hard face sizing controls which override the sizing functions for adaptive meshing along the face. you could do this by mesh>insert>sizing, specify the desired element size and scope to the the required face. In your case the mesh looks good but if you wish to refine it further you could either increase the resolution(which will refine globally) or add local sizing control.nRegards,nIshan.n
