1shan
,nContacts are used to connect 2 bodies when it is not possible it ensure a node-to-node connectivity( which is generally the case for most assemblies). A bonded contact is a linear contact so this will not add any nonlinearity to the model. Both approaches should give you a similar answer.nnRegards,nIshan.n
