Karthik R
Administrator
Hello,nIt is hard to comment on the material properties. But, here are some suggestions: nYou can obtain the material property data from the material manufacturer. They might be able to confirm the properties you are using in this simulation. nIf cannot do this, I'd recommend that you either estimate these in the lab or look into the literature on what others have used for the same material.nKarthikn
