Karthik R
Administrator
Hello,nYou can do this by conducting a parametric analysis. You will be defining the mass flow rate as an input parameter. You will obtain the pressure head as the output. In your design table, you can vary the input mass flow rate and WB (and Fluent) will report the output pressure head. nThank you.nKarthikn
