Sean Harvey
nI am not certain if I am missing anything, but you can use the *do loop and then put in *if and if i =1 assign to some nodes (D) delete from other (DDELE). If i=2, assign to some nodes, or just copy the B/C and solve and paste again with the new numbers so you have D commands, then DDELE to remove if you don't want them, then solve and you repeat.nDoes that help?nThanksnSeann
