nPlease clarify which data is from the simulation. Is it the blue curves? Why are there two plots?nAre you trying to get the envelope of the blue curves to reduce the magnitude of Moment as the cycles build up?nYou haven't given nearly enough information to get help.nWhat material model are you using for Plasticity?nWhat constants are you using in those models?nYou haven't shown the mesh. Did you do a mesh refinement study?n
