DrAmine
Yes: better to monitor the mean velocity at the outlet.nFrom your mass balance it seems the case as I mentioned from the beginning is on his way to balance (but still high amount of imbalance which might be due to negative accumulation too) Just run for longer time and check it again. Also monitor key variables like mean velocity at the outlet.n
