Custom Field Function will give you the RHS which you can plot against position. Line/rake should give all the points in order, try plotting against length over position and see if that helps. If you picked points on an external surface (or one bounding a solid zone) move the points into the fluid:you may be clipping the line if it's switching between fluid & solid or fluid and outside. n
