1shan
Hello Array,nYou could try simplifying the geometry by merging faces using spaceclaim -
" target='blank'>
. Another alternative is using the shrink-wrap command in the reverse engineering tab. If that doesn't work try converting it to solid, use a mesh method and set it to tetrahedrons-patch independent.nRegards,nIshan.n
