April 19, 2021 at 1:01 pm
Hallo ,nmy problem is that it looks like there is a **** when I plot the deformation in true scale as you can see below:n
You can see the contact between these two bodies below:n
below you can see the contact pressure of this contact:n
I am a little bit confused because on the first picture it looks like there is an **** but on the last picture I got an contact pressure, so I think these two bodies can not **** each other?nIs the first picture just an graphic error, or is this true and there is an error with the contact pressure?.I hope you know what I mean?nYou can see the initial informations of the contact bellow:n
nnBest regards,nbokaJ
