wcao
Hello,nIf you are using import chemkin mechanism in Fluent, the unit conversion is automatic. You can find that the values in the reaction mechanism will be different than that in the mechanism file due to unit conversion. However, if you are manually input the values, you will need to convert them by yourself. Thank you.n
