Karthik R
Administrator
Hello,nIf you are running a steady-state simulation, the Solar irradiation data is printed to your Fluent console right after you initialize your problem. Other than this, you can use Post-processing quantities such as Solar Heat Flux, Absorbed visible and IR solar flux, Reflected visible and IR solar flux, Transmitted visible and IR solar flux to understand the load distribution in your simulation. nFor more information, please look at the following link.nKarthiknn
