You'd need to set the inlet to be the outlet temperature and update every time step. Then monitor the surface/point with time to see the temperature. Passing an average temperature & velocity back to the inlet is fairly easy, passing the facet values back is less so. But there's also what your experimental set up does to the water as it leaves the section, that may play a part in the end result. n
