1shan
Hello Array,nUse the bolt pretension object instead of applying a force to bolt head. You could check these videos
" target='blank'>
" target='blank'>
and
" target='blank'>
. What kind of contacts have you defined. You could start by providing a fixed support to both the end faces of the bo ne, a bonded contact between bolt thread and inside surface of the hole , and a frictionless contact between the plate and bo ne surface. Also check the material properties and turn large deflection On under material settings. You could monitor the force reactions and adjustment using bolt tool in results.nRegards,nIshan. n
