1shan
,nOn what basis do you say that the stress is high and strain is low? Have you compared the results with some published results? If yes, how much difference are you expecting? Have you tried doing a stress convergence study and check if the mesh is fine enough. Also check the material data used is same as that in the literature to which you are comparing.nRegards,nIshan.n
