sergiofr
When using the full folder path solves the problem, but I was looking for a solution with a relative path as it is more easy to configure cases. If I use full path, I should go through all the different cases and all the animations and figure definitions to specify the full path. Could it be possible to configure Fluent to work with relative paths for animations and figures? Indeed, it can work with relative paths for Report Definitions and Transient exports...n
