rahmanmahfuz11
HelloArray,nYes, I am also keeping my finger crossed on assembly workflow being flexible in future releases. nAnother thing, Having looked at your model though another solution may also have been to mesh the rollers coarsely, then use contact geometry correction to ensure the contact behaved as a perfect cylinder. - I haven't been able to clearly understand what you meant by that. Have you meant not defining the cylinders as rigid bodies & use contact geometry correction to ensure that they behave as rigid bodies although they have been defined as deformable?n
