Surya Deb
Hello, nSince your inlet boundary condition is periodic with time, you will see some residual fluctuations as well.nDid you try to make use of Coupled Solver for this case?nDo you see reversed flow from the outlet? If so, then you might consider extending the outlet further downstream.nRegards,nSDn
