Sheldon Imaoka
Hi altupaka,nThe *VFUN,,EULER command may be what you're looking for. You would supply an nx6 array of your stress components (you can use *GET or *VGET to get the stress values), and the output is an nx3 array of Euler angles. Since the output is in an array, you can then use *CFOPEN and *VWRITE, for example, to write out the data in whatever manner you want.nRegards,nSheldo
