utkarsh751
Thank you for letting me know. For the analysis, I am using RHINO to make the model. In the ANSYS software, I can see that each element of my model is being treated as a face. And I am also able to see the forces on the edges of the faces as well. The only problem I am having is that the numbering of the nodes is not consistent. I will attach 2 pictures to give the reference. The number of nodes are much more than 30 I am giving reference to (the picture is just to show that the numbering is not consistent) - yellow is the input from my input RHINO file and the white is the output from ANSYS after doing the CFD from Fluent. njust wanted to explain my problem better and to be sure that may be there is no solution to keep it consistent.nn
